Click for Northern Lights Click for Glendinning Click for Nordhavn Click for Perko Cick to Clean Black Water
Feature: Nobiskrug 73M Superyacht "Odessa II"
Discussion in 'Nobiskrug Yacht' started by Yacht News, Jan 12, 2016.
  1. 73-meter Superyacht "Odessa II" By Nobiskrug
    The 73-meter superyacht christened as "Odessa II" started out build life at Abu Dhabi Mar Kiel and then was completed by Nobiskrug for her owner. The design is by Focus Yacht while the quite elegant interior has been formulated by H2 Yacht design. It was fashioned to echo a New Hamptons style that was comfortable for the owner and family to enjoy. Hull 423 as she was known as at the time of construction was built with a steel hull and an aluminium superstructure. The hull was built at HDW –at the time- and represents a familiar hull platform. We have seen a similar hull completed as superyacht “Plan B”. Odessa II although at 73-meters offers a quite a bit of room for her owner and guests.
  2. The sundeck is the uppermost deck of the four decks onboard available to guest comfort. It is comfortable and prepped for relaxation. It is split between three areas with the forward section aimed for relaxation. This model from Nobiskrug features the ability to have a helicopter land touch-and-go style on the roof of the bridge but on Odessa II it is usually kitted out for outdoor furniture. Further back a Jacuzzi awaits the yacht’s guests and ample sunbathing pads are available on either side of the Jacuzzi. The wavy cut to the sunpad built-in area also provides an aesthetic appeal. Sun awnings can be erected by the crew to help partially shade the deck both fore and aft.
  3. The interior by H2 Yacht Design focuses on light beige tones and contrasted in some rooms by dark veneers. Accommodation is offered for twelve guests in seven staterooms including a full beam master suite with panoramic views. Where ever onboard the owner and guests will appreciate her 40-foot beam offering a more-than-comfortable experience whether in the main salon, the upper salon, the sundeck or in the cabins, the space offered to the guests is evident. Makes little sense having a 70-meter-plus superyacht it is lacks adequate space.
  4. Besides the grandeur, the interior is finished with a number of fancy and precious materials. One reoccurring theme in various rooms onboard is the use of back-lit stone. Ranging from the ceiling fixture in the main saloon, to the bar, to the feature wall in the spa/massage room. Back-lit stonework is utilized to turn the notch up on the luxury appeal for the owner. The floors also offer variety in the finish. There is a different look to the floors in most of the rooms onboard and it may range from exquisitely finished teak-like materials in a longitudinal fashion to a more intricate repeated ‘W’ style or try luxurious soft carpeting in the guest cabins.
  5. The owner’s suite is on deck and forward in location. Other cabins for guests are spread around but primarily total seven onboard. There is the owner’s suite, two doubles, two twins a convertible cabin –if needed- and a single cabin. There is also accommodation for as many as nineteen crew-members if needed. The master suite is full beam and benefits from a flush-fit fold-down balcony large enough to hold the owner and partner on those days or nights at anchor in serene bay locations around the world. The main room features a very large bed and a large bathroom stunningly outfitted and finished in lavish materials. As nice as the master is, once the owner is onboard none of the other guests can access it so it’s back to the sundeck for more guest relaxation.
  6. Last time (earlier) we only visited the forward portion of the sundeck. Midship on this particular deck is an enclosed/indoor room that houses the yacht’s gym! So you can sweat it out in air conditioned comfort if you wish, while shaving a few pounds off. Aft of this area is dedicated to sit-down relaxation. With the sun awnings installed this area of the deck shouldn’t be too hot and even if it is, the yacht is equipped with a fog/mist cooling system. More guest spaces are on the lower deck too.
  7. One of these areas is the beach club. Odessa II’s beach club may not be the most expansive onboard a superyacht today but it sure isn’t that small either. It’s a decent space to give another option to the yacht’s guests to relax. The spa is down there too and if you want some of those kinks rubbed out, the massage bed isn’t far away. Odessa II is easily distinguishable from her sister hull Plan B with a grey hull (Plan B has a cream-coloured hull). She has ocean-crossing range and can sprint to nearly 18-knots thanks to her pair of diesel-fed MTU 16V 4000 M60s. She has also engaged in charter and has watersports equipment to satisfy the avid waterman/woman onboard. Her main tender is a special vessel built by Hacker Craft. The deck of the main tender is constructed of mahogany and the hull and topsides of okume/epoxy/fiberglass. Thank you for stepping aboard superyacht Odessa II with us, now collect your shoes from the end of the passerelle!
    Nobiskrug GmBh
    Kieler Straße 53
    24768 Rendsburg
    www.*************
