Click for Abeking Click for Westport Click for Westport Click for Walker Click for Glendinning
My First Dirty Bottom Experience
Discussion in 'General Yachting Discussion' started by DOCKMASTER, Jun 25, 2026.
  1. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    No, not that kind of experience. Get your minds out of the gutter
    We are doing a two week trip on our boat in Baja. Arrived here and could see the bottom wasn’t cleaned. Our divers had some equipment issues and got behind schedule for several weeks. We went out for a day trip and all was running great. However, after coming up to around 1800+ rpm’s I glanced down and saw my engine load was showing 93% on both sides - WTF? I should be around 65% or so at that rpm. It did come down some after the initial speed up but still way high. In a bit of a panic I’m looking at everything to find the problem. All gauges were green, no other obvious issues, no heavy smoke, etc. I was racking my brain trying to figure out what could cause this on both engines at exact same time? Then it dawned on me, could the bottom be that dirty? After about 15 mins of run time it did drop to 77% load at 1825 rpm. Better but still way high. We were only going a short distance so I just slowed down and we finished our day trip without incident.
    Divers showed up yesterday morning before our departure. They said the bottom wasn’t terrible (because we just ran it) but the props had a lot of those rock hard white worm thingys on them. They did a good job getting her all cleaned up. Left the marina yesterday and all back to normal. 1825 rpm and load at 64% with throttle position 63%.
    I’m aware of how a dirty bottom can affect things but I was not aware of how significant even mild fouling can be an issue. Time to get prop speed on my props and shafts at next haul out.
    Here’s my morning view somewhere in Baja.
    d_meister likes this.
    It's amazing how much those worms on the props will slow you down. Down there, you almost have to run the boat at cruise every 2 weeks. Prop speed doesn't keep them from growing, and they don't fall off when you run the boat, just makes it easier for the diver to get them off.
    motoryachtlover likes this.
  3. DOCKMASTER
    Ketchikan, Alaska
    Thanks, good info. I have the bottom cleaned monthly but they were almost 3 weeks late this time. I’ll monitor to see if monthly is enough. I might have to increase interval in the summer months. Especially given we use it less often this time of year due to the heat.
    Strawberrylor likes this.
  4. Vaquero
    Vaquero New Member
    Newport Beach, CA
    I have a Cabo 40 in Puerto Los Cabos for the last few years. Starting in May through December I have the hull scrubbed every 2 weeks. Prop speed is your friend, as noted it doesn't prevent the white worms / hard critters but it slows them down. For whatever reason they don't grow on my prop shafts. That 80 degree water makes everything grow. Check your sea strainers for Mains, AC's, and Genset frequently. Being Mexico I have had transient slip neighbors over the years and some boats have bonding issues and leak current so keep an eye on your zinc's as well.
    MM3 likes this.
  5. DOCKMASTER
    Ketchikan, Alaska
    Good info, thank you! Funny you mention leaky current from other boats. I just moved slips as I’m convinced the boat that was next to me was eating my transom zinc plates. I’m already on #4 and I’ve only been here 7 months.
    Yep.
    All kinds of stuff from surrounding boats.
    Just start walking by and open his (offenders) dock service breakers (if your not on video).
    Now that were not on a dock with others anymore, I can mention that this may have happened a few times.
    The open breaker boats did take some hints and moved,,,, aweigh from our boat.
    May I suggest some galvanic isolators. Not a fix for all issues but helps a lot.
    Please remember your Not in Kansas anymore. Others including the dock managers could not care less.
  7. DOCKMASTER
    Ketchikan, Alaska
    This is a pretty high end marina. Lots of security, cameras, etc. Most boats here are bigger, newer and way more expensive than mine. I’m convinced they only let me in to lower the net worth of the neighborhood a bit . This also lets the big boys feel better about themselves when they see my old boat here. There is no way I’m going to go and open anyone’s breaker. The potential damage or even loss of their freezer food is probably worth more than my house.
  8. Capt Ralph
    If it is so much of a high end marina, then why did they let in a stray current (cheap) boat?
    If it really is that high end, Better start talking with the dock master as WTF is happening to your zincs.
  9. DOCKMASTER
    Ketchikan, Alaska
    Sounds like someone was a little grouchy yesterday evening
    I guess things are different in Florida. I’ve never been in a marina anywhere on the left coast (high end or otherwise) that I have seen them go around probing the water testing boats for stray current. I’m not saying it doesn’t happen, just that I’ve never seen it. The boat I suspected is actually a very nice Hatteras Sportfish. But some of the maintenance and upkeep looked a little lacking. If I continue to eat zincs at the new slip I will be probing my own boat and the docks and boats near me.
  10. Capt Ralph
    I get grouchy quickly when a friend has problems. Even very little problems like their zincs not lasting.
    I want to flip breakers and throw supposed electricians in the water.
    :confused::oops:
    While in the Jax area, is was very common for techs to be dipping silver leads in the dock side water.
    Amazing what you can discover with an ole Simpson & O-scope.
  11. Capt Ralph
    So you have gone thru this before.
    If your green wire isolated and still burning up your zincs, some high end boat around you does have a problem.
  12. DOCKMASTER
    Ketchikan, Alaska
    Yes but that was before I renewed all the wiring throughout the boat for all bonding. Haven’t issues like this since then.
